| Dual manual m/c for drum brakes https://slantsix.org/forum/viewtopic.php?t=58055 |
| Author: | OleSkoolTony [ Mon Jul 13, 2015 12:35 am ] |
| Post subject: | Dual manual m/c for drum brakes |
Where can I find this: http://m.ebay.com/itm/1966-A-Body-Manua ... nav=SEARCH For my 66 valiant? I'm ok with drum brakes, but I feel the single master cylinder is very risky. Thanks yall, cheers! |
| Author: | Reed [ Mon Jul 13, 2015 1:06 am ] |
I don't know of a kit, but you need the master cylinder, proportioning valve, and front brake lines including the lines between the master cylinder and proportioning valve from a 68-up drum broke A body. Probably easier to buy a new MC and some universal lines, a tubing bender, and a double flaring tool. |
| Author: | OleSkoolTony [ Mon Jul 13, 2015 1:17 am ] |
Thanks. I'll start looking on rock auto. |
| Author: | 70valiant [ Mon Jul 13, 2015 4:26 am ] |
I put a dual master in my 66 Dart, I just pulled the rear line from the distribution block plugged the hole in the distribution block, I added some new line to the rear line using a coupling and connected it to the front reservoir. I then hooked the line going to the distribution block (which now only serves the front brakes) to the rear reservoir of the master. I put one in from a 73 duster but the pedal never gets hard, I will some day replace it with the same style that came stock in my 66/67 Valiant. |
| Author: | 70valiant [ Mon Jul 13, 2015 4:29 am ] |
Reed, He doesn't need a proportioning valve its four wheel drum. |
| Author: | Reed [ Mon Jul 13, 2015 9:27 am ] |
Quote: Reed,
D'OH! I usually just swap to discs so I am a bit rusty on all drum brake systems.
| Author: | slantzilla [ Mon Jul 13, 2015 10:42 am ] |
I used the master and distribution block off of a '71 Demon. The master bolted right on. It had a cutout that left an open hole in the firewall I filled with black silicon sealer. I made up a couple brake lines and called it a day. |
