| Brake line kit question https://slantsix.org/forum/viewtopic.php?t=58071 |
| Author: | hideogumperjr [ Wed Jul 15, 2015 1:46 pm ] |
| Post subject: | Brake line kit question |
Hi Folks, I am going through my brakes for my car and have found this flexible brake line kit on ebay and I am wondering if anyone has used this before and what their experience or comments may be on them. Also any caveats to look out for. Thanks John http://www.ebay.com/itm/Brake-line-kit- ... 30&vxp=mtr |
| Author: | kesteb [ Wed Jul 15, 2015 7:56 pm ] |
Buying bulk line from NAPA and making your own would probably be cheaper. Especially if somebody thinks they need them more then you and bids the price up. |
| Author: | hideogumperjr [ Wed Jul 15, 2015 10:26 pm ] |
Thanks, Ive been checking them and the one up for bid is only a buck and a half more. I did the bulk brake line upgrade on my other car and bending to get into the tight places while on my back under the car was a real pain so I thought this might be a better way (read that easier for my old body!) than bending the bulk stuff. Thanks again! |
| Author: | Reed [ Wed Jul 15, 2015 10:54 pm ] |
I have never used that kit but the price sure is attractive. Worst case scenario, I have a tubing bender and a double flare tool you could borrow to make up your own lines. But $53 sure sounds better than hours of futzing around with a tubing bender and flare tool on your back! |
| Author: | SlantSixDan [ Wed Jul 15, 2015 11:11 pm ] |
Skip steel line entirely. Read this entire thread. |
| Author: | Pierre [ Wed Jul 15, 2015 11:44 pm ] |
I don't think that kit is steel line. Title just says metal. Description says Quote: These maliable lines are easy to bend or coil without collapsing the tubing or restricting the flow of brake fluid.
And pic a bit below that shows it being bent by hand.
| Author: | hideogumperjr [ Fri Jul 17, 2015 3:26 pm ] |
Thanks for the info guys. I surely like the idea of a long lasting and easily bendable line. Especially when it comes to buying more expensive one use tools. By the way the listings I find online show the other suggested lines as being Nickel Copper alloy so no steel but they support the high pressures ratings. Cheers. |
