It is currently Fri Nov 20, 2026 5:10 am
PostPosted: Mon Aug 03, 2015 2:17 pm
I know to go with rubber, put a little grease on in place of hy..whatever that stuff was called in the other thread. Any suggestions on a good gasket outside of the usual Felpro?
Thanks!
PostPosted: Mon Aug 03, 2015 3:34 pm
Genuine Chrysler (probably NLA) or Fel-Pro rubber gasket. No need or benefit to applying grease or oil. As far as I know, nobody else makes a rubber gasket. You can get one made of silicone, but you probably shouldn't; see here.
PostPosted: Mon Aug 03, 2015 4:29 pm
Thanks! It doesn't need one right now, but when I decide to adjust the valves out, I'll have one ready to go.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 3 guests
