| Valve Cover Gasket suggestions https://slantsix.org/forum/viewtopic.php?t=58172 |
| Author: | Luftwaffles1000 [ Mon Aug 03, 2015 2:17 pm ] |
| Post subject: | Valve Cover Gasket suggestions |
I know to go with rubber, put a little grease on in place of hy..whatever that stuff was called in the other thread. Any suggestions on a good gasket outside of the usual Felpro? Thanks! |
| Author: | SlantSixDan [ Mon Aug 03, 2015 3:34 pm ] |
Genuine Chrysler (probably NLA) or Fel-Pro rubber gasket. No need or benefit to applying grease or oil. As far as I know, nobody else makes a rubber gasket. You can get one made of silicone, but you probably shouldn't; see here. |
| Author: | Luftwaffles1000 [ Mon Aug 03, 2015 4:29 pm ] |
Thanks! It doesn't need one right now, but when I decide to adjust the valves out, I'll have one ready to go. |
