push button gear selection
https://slantsix.org/forum/viewtopic.php?t=5822
Page 1 of 1
Author:  black nails [ Thu May 22, 2003 10:44 am ]
Post subject:  push button gear selection
:?: On the 62 dart I am reviving the park lever want release after being set. I have gotten around by leaving lever disengaged, and using the park brake when I get out. The push buttons for gear selection all work fine. Does anyone have ideas on how to rehabilitate the park setting?
Author:  slantvaliant [ Thu May 22, 2003 1:35 pm ]
Make sure the parking pawl is assembled correctly, and that the spring leg engages the cable end when you install it.
I had a heck of a time with a rebuilt transmission in my '64. The pawl assembly was misassembled by the shop. I found and repaired that, but they had made other mistakes that took longer to find and fix.
