| Backfire through Carb, Timing Issue? https://slantsix.org/forum/viewtopic.php?t=58263 |
| Author: | Slant6-M37 [ Tue Sep 01, 2015 11:30 am ] |
| Post subject: | Backfire through Carb, Timing Issue? |
I recently added the GM HEI Conversion to my truck and now it backfires when under a load. In addition it is running very rich. Should the timing have been adjusted after doing this? I have not been able to find any info on the settings with the HEI conversion. I probably should also look at adjusting the carb but I don't know which to do first. Any help would be appreciated. |
| Author: | JBracey [ Tue Sep 01, 2015 3:36 pm ] |
| Post subject: | Distributor Wires |
You might have your distributor wires backwards on the HEI module. I know when I did mine I had them reversed the first time. |
| Author: | Reed [ Tue Sep 01, 2015 3:37 pm ] |
Timing and carb setting should remain what they were before the swap. The only thing HEI does is provide a longer dwell period and a hotter spark. That's it. I second the suggestion that you try switching the pickup wires going to the HEI unit. |
| Author: | Slant6-M37 [ Fri Sep 04, 2015 5:24 am ] |
Thanks for the responses, I'll check that out this weekend. |
| Author: | Slant6-M37 [ Wed Jan 06, 2016 7:15 am ] |
Thank you again for the suggestions on fixing this problem. I just got back to working on the truck and I found by back-tracking through everything the the back-firing was being caused by the #5 and #6 spark plug wires being in the wrong locations on the distributor. |
| Author: | 64DartGT [ Wed Jan 06, 2016 8:23 pm ] |
Way to go, glad you figured it out!! |
| Author: | wjajr [ Thu Jan 07, 2016 5:58 am ] |
Quote: caused by the #5 and #6 spark plug wires being in the wrong locations on the distributor.
You can't beat simple; no tools were abused in that repair.
