It is currently Fri May 15, 2026 6:30 am
 Post subject: track frame crack
PostPosted: Sun Aug 09, 2015 9:30 pm
Car Model: 1964 Valiant
This weekend I saw a '91 D150 with a cracked frame just behind the upper control arm on the passenger side. The truck was not rusty nor had it been in a collision. Is frame cracking a common problem? The truck had a V6, probably not much weight on the front end.
PostPosted: Wed Sep 02, 2015 10:55 pm
Only ones I ever heard of having issues were the early Cummins powered trucks.
PostPosted: Thu Sep 03, 2015 12:01 am
Ive broken a frame on a D100 by jumping it off road. But it was further back from the A-arm near the Z-bar. Maybe something like this happened?
~Nic
PostPosted: Thu Sep 03, 2015 7:36 pm
The frame on my old '72 D100 cracked at the steering box. This was a problem on the older trucks .i.e. '72 on.
 Post subject: ..cracks...
PostPosted: Fri Sep 04, 2015 3:37 pm
I grew up in PA where rust is king and cracks were common. My Dad's '69 ford pickup frame had more welding rods in it than original metal...
brian
https://tinyurl.com/yynpj4v2
