| '64 vs '65 Valiant https://slantsix.org/forum/viewtopic.php?t=58363 |
| Author: | SlantSixDan [ Fri Sep 18, 2015 10:44 am ] |
Yes, it's compatible. The only physical "gotchya" you could run into is if you were asking about swapping '63 versus '64-'66 doors, which is "no" because different latches. See here, here, here. |
| Author: | polara pat [ Fri Sep 18, 2015 11:02 am ] |
Thanks Dan, you always know. I didn't know that '66 would also be the same for the two door conversion as well. I've had a few of those over the years and there are a couple descent ones in the local wrecking yard.
| Author: | sandy in BC [ Fri Sep 18, 2015 5:28 pm ] |
"here here and here" Wow that looks sharp. |
| Author: | polara pat [ Sun Sep 20, 2015 8:09 pm ] |
Quote: "here here and here"
I'm clearly not the first one to think of this mod but I do have a descent vision for the project and the skill to pull it off.
