Fuel filter -- 2 or 3 port difference?
https://slantsix.org/forum/viewtopic.php?t=58448
Page 1 of 1
Author:  SageRad [ Tue Sep 29, 2015 5:53 am ]
Post subject:  Fuel filter -- 2 or 3 port difference?
Yesterday i removed the cannister, and capped off all the connections it had used.
Now i want to change my fuel filter, and i see that the current one has three ports.
I'd expect two ports -- fuel in and fuel out.
So what is the third port for, and does it go back to the tank or what?
I want simple.... fuel comes up, and into the carb.
Can i replace it with a simple 2-port filter and cap off whatever the third connection is?
Author:  SlantSixDan [ Tue Sep 29, 2015 1:05 pm ]
Post subject:  Re: Fuel filter -- 2 or 3 port difference?
Why? Disabling the canister is not only unsafe if done wrong (which it sounds like you might've), but even if done "right", it's not an upgrade, it's a downgrade.
Discussed in Fuel line mod.
You sure you wouldn't rather have the setup that works best, instead of the setup that is "simplest"?
