| Burning oil... https://slantsix.org/forum/viewtopic.php?t=58456 |
| Author: | Vakha [ Wed Sep 30, 2015 6:54 am ] |
| Post subject: | Burning oil... |
Hello, Its my first post here. My name is Targo and im from Estonia Next question is not engine related but rather a car frame. I am hardly an expert but i dont think its supposed to look like that. Looks like metal is cracked. |
| Author: | SlantSixDan [ Wed Sep 30, 2015 8:22 am ] |
Welcome! How many miles (or km) has this engine run? The engine should not burn so much oil. Your mechanic is right that it is not unusual for an old engine to burn a lot of oil -- that is what happens when an engine is worn out. But it is not "normal"; it can and should be fixed. It is possible there are leaks you cannot easily see. For example, the oil pressure warning light switch can leak in a way that doesn't make a mess for evidence. The first thing to do is careful investigation to make really sure there are no leaks. Then it's time to check carefully for oil burning. What do the spark plugs look like? I agree with you: the metal looks cracked, and it shouldn't. |
| Author: | Old6rodder [ Wed Sep 30, 2015 10:10 am ] |
Rather an odd place and run for a crack. Perhaps a wire brushing'd show an overlap and some welds. |
| Author: | Jsp [ Wed Sep 30, 2015 10:41 am ] |
I think it looks like someone strenghtened it with a piece instead of a crack.. |
| Author: | NEVjr [ Wed Sep 30, 2015 2:50 pm ] |
it looks like s folder over seam with welds to me, not a crack slants have lots of spots to leak oil from, a joke i heard once: "fill the oil and check the gas please" is it a rear main seal and its only leaking while running and under load? you might not get a stain, but when you step on it to go up hill the blow by could push the oil out there. the oil pan and bottom of the timing cover look clean, how about the valve cover? try putting cardboard under it and run it for a bit, see if you spot anything |
| Author: | '67 Dart 270 [ Wed Sep 30, 2015 3:20 pm ] |
| Post subject: | Welcome (again)! |
I agree with NEVjr, that looks like a weld and seam to me, yes, wire brush it and send another pic for us... Estonia, cool! I had a college professor from Estonia, Vootele Vaska (philosopher); his older brother Lauri is a famous chemist. Brian |
| Author: | Vakha [ Thu Oct 01, 2015 12:41 am ] |
Quote: Welcome!
Its hard to say how many miles. Odometer is broken. On paper it says engine was swapped out in 1999. Right now it shows 30k miles, but it might be 130k or even 300k. God knows. Il check all the other stuff in weekend when i have more time. Thanks for those quick replays.
