| No compression in 2 cylinders -head off with pics- question https://slantsix.org/forum/viewtopic.php?t=58469 |
| Author: | Joshie225 [ Fri Oct 02, 2015 3:02 pm ] |
I can't see pictures here at work, but what I do to investigate a loss of compression is take the valve out of the end of my compression tester hose and put air into the cylinder to see where the air goes. Last time I did this I found leaky exhaust valves as they had been set too tight before I got the car. Having taken the head off makes this impossible so... Put the head on the bench chambers up and fill them with Kerosene or something similar to see if the valves leak. Check the valve stem heights as you might have valve seat recession. Have the head magnafluxed to see if it's cracked. |
