| shifter https://slantsix.org/forum/viewtopic.php?t=58493 |
| Author: | '67 Dart 270 [ Mon Oct 05, 2015 9:15 pm ] |
| Post subject: | shifter |
I have an A-904 automatic. Just today, when I shifted into drive, the shift selector was really rough, like the internals in the steering column were scraping along. When I shift into other gears it is smooth. Do I need to take the column apart to lube this, or can I squirt some WD40 in there or something? I'm concerned because it really feels rough going into drive; I don't want it to fail before I have time to take it apart or whatever is needed to fix it. The tranny is working fine, this is in the shft mechanism in the column. thanks brian |
| Author: | '67 Dart 270 [ Tue Oct 06, 2015 10:45 am ] |
| Post subject: | I couldn't wait... |
I shot some WD40 in there and worked it around, and now it's fine, very smooth again. Is more purposefully placed and/or heavier and/or alternative lubrication needed? Brian |
| Author: | Reed [ Tue Oct 06, 2015 10:57 am ] |
I can't say, but I am parting a 68 Dart and I have a complete (minus steering wheel) steering column for an automatic as well as the entire shift linkage from the column to the transmission. |
| Author: | Dart270 [ Tue Oct 06, 2015 11:40 am ] |
Sounds like lube did the trick. I would suggest getting a higher quality lubricant than WD40, such as PB Blaster spray silicone lubricant or spray white lithium grease. WD40 is not a particularly good lube. It does a few things OK, and for the short term, but is not really very good at anything. Lou |
| Author: | Greg Ondayko [ Tue Oct 06, 2015 11:44 am ] |
Quote: It does a few things OK, and for the short term, but is not really very good at anything.
It's Good for making old patina'd paint look shiny and Matte clear coated.Lou I might Have to use some of the 64 dart! Greg |
| Author: | '67 Dart 270 [ Tue Oct 06, 2015 4:13 pm ] |
| Post subject: | Thanks all... |
I try some silicone or better lube in there as a chaser... brian |
