| Need adjustment specs for Holley 1945 R9890 https://slantsix.org/forum/viewtopic.php?t=58523 |
| Author: | MattyBrown [ Sun Oct 11, 2015 2:45 pm ] |
| Post subject: | Need adjustment specs for Holley 1945 R9890 |
I just got done with a rebuild of my Holley 1945. Only problem is I'm not sure how to properly make adjustments. In the past I had followed the specs from the Chrysler training video which I'm assuming is from '74 or '75. But what I never stopped to realize is this is a late model of the 1945 and those specs probably don't match. SlantSixDan told me when I purchased it that it was the last revision of the 1945 from 1989. The model number on the carb is 9890 or R9890. The rebuild kit I bought comes with a list of adjustment specs from 1974-1980, so I'm not sure which specs to go by. The Choke Pull-Off adjustment varies quite a bit year by year and also depending on whether its a car or truck. I really want to make sure this carb is fine tuned to perfection. Does anyone have any idea where I can find the proper specs for this specific model carb? THANKS!! -Matt |
| Author: | matv91 [ Sun Oct 11, 2015 6:10 pm ] |
From holley book 9890 after market replacement carb for 1980 chrysler cars 225 all trans, federal emissions. Dry float .047 pump link hole no 3 choke unload at wide open .250 vent valve adjustment .070 choke vacuum kick .104 . Well thats what the book says. Good luck |
| Author: | MattyBrown [ Mon Oct 12, 2015 8:14 am ] |
Hey matv91, Thanks for the info. Can you clarify a couple things real quick? For Choke Pull-Off, or Choke Vacuum Kick as your wrote it, is .104" correct or did you mean to write .140"? Does your book specify Slot 3 as being for Automatic or Auto & Manual both. Most of the spec sheets I'm seeing have Auto & Manual as different slots. My car IS automatic. Also, did they include a measurement for the pump linkage? Just curious, what book are you getting this from? THANKS FOR THE HELP!! -Matt |
| Author: | matv91 [ Mon Oct 12, 2015 5:18 pm ] |
For Choke Pull-Off, or Choke Vacuum Kick as your wrote it, is .104" correct or did you mean to write .140"? Thats holleys term.The complete phrase in the book is [choke qualifying dimension ,vacuum kick ] holley book says .104, that could be a typing error?. fsm 1980 .110 for canda carbs, US auto .140 manual .150. There was a tech bulletin for 1980 auto cars built prior to february 1980. bulletin number 14-06-80. A new choke vacuum diaphram pull-off,chrysler part number 4240064 and choke coil assembly part number 4095332.Choke pull off spec changed to .130 |
| Author: | matv91 [ Mon Oct 12, 2015 6:21 pm ] |
Does your book specify Slot 3 as being for Automatic or Auto & Manual both. Most of the spec sheets I'm seeing have Auto & Manual as different slots. My car IS automatic. Also, did they include a measurement for the pump linkage? Slot 3 for both auto and manual and no measurement for pump linkage. |
| Author: | matv91 [ Mon Oct 12, 2015 6:29 pm ] |
Just curious, what book are you getting this from? Holley illustrated parts and specs |
| Author: | matv91 [ Mon Oct 12, 2015 7:21 pm ] |
The orignal 1980 carb used holes no slots.The early carbs used slots.Also the 74 carbs measure for pump adj at a different loction than the 75 carbs.Info from 74 75 76 service manuls.After market replacement carb,was your carb number listed in your kit. |
| Author: | SlantSixDan [ Mon Oct 12, 2015 8:03 pm ] |
Quote: fsm 1980 .110 for canda carbs, US auto .140 manual .150.
I'd use the Canadian-spec adjustment for best cold-engine driveability.
| Author: | matv91 [ Tue Oct 13, 2015 7:25 pm ] |
Its late but the short answer ,leave it alone. My best guess from the fsm 74 5 6 79 three different measurement points. Depends on year and slots or holes.2-21/64 common for automatics 75 76 with slots. Post up your whole sheet. And measure where its at now and compare. |
| Author: | SlantSixDan [ Tue Oct 13, 2015 10:18 pm ] |
There are specs for all the adjustments in the Holley master carb catalogue. I used to have that book, but I no longer do. Anyhow, if the car's running and driving well...enjoy and don't worry so much about 3/16" versus 5/32" or 0.110" versus 0.135". |
