| Guages, radio, turn signals etc don't work when its cold out https://slantsix.org/forum/viewtopic.php?t=58690 |
| Author: | ESP47 [ Thu Nov 12, 2015 2:52 pm ] |
| Post subject: | Guages, radio, turn signals etc don't work when its cold out |
This is on a 75 Dodge D100 automatic. If I turn the key to accessory, everything works fine. When the key is in run, I can't get most of the electronics to work other than the dash lights, head lights, brake lights etc. Before I go tearing into the column thinking it's the ignition switch, are there any other components I should be looking at? This only happens when it's cold outside. After the thing has been sitting in the sun for a while, everything works like it should. |
