It is currently Wed Apr 29, 2026 10:02 pm
PostPosted: Thu May 29, 2003 1:49 pm
Car Model: 1965 2 Dr Sedan, Wagon, Barracuda and Convertible
I'm about to take the plunge and rip my '65 833 apart. The syncro's are embarrassing. If I've got it apart anyway, why not rebuild it in an aluminum case? I've located one near here for $50. I have a couple of questions before I start.
1. Will the guts of my '65 833 just drop inside an aluminum case?
2. I will need to shorten my Drive Shaft for the 8 3/4 I'm also putting in. Should I change over to the newer tailshaft also?
3. What do I need to ask for when I order a rebuild kit for this "non-standard" setup.
4. What other surprises am I headed for?
Mike
1965 Valiant 200 /6 2dr Sedan.
1965 Valiant 200 V8 4dr Wagon
1965 Barracuda /6
1965 Valiant Convertible V8
PostPosted: Fri May 30, 2003 12:25 am
I'm about to take the plunge and rip my '65 833 apart. The syncro's are embarrassing. If I've got it apart anyway, why not rebuild it in an aluminum case? I've located one near here for $50. I have a couple of questions before I start. (see below)
Mike
You need to check to see if the Alm. case uses the larger "308" front bearing and larger bearing retainer, if so, that means the 65's bellhousing pilot hole will be to small for the larger front bearing and retainer.
Yes and Yes
Order syncrows for the 65 trans but the seals and bearings for the Alm. case "later" gearbox.
You should get the later "wrap-around 1st - 2nd shift fork.
Did you read through the 4-speed article?
PostPosted: Fri May 30, 2003 1:17 pm
The '65 tranny should have the B&T U-joint. You will need to swap the tail shaft to one that will work with the aluminum tail case. I don't think this is an easy thing to do...
 Post subject: more
PostPosted: Fri May 30, 2003 4:25 pm
I don't have any first hand knowledge regarding the aluminum 4spd. I have swapped the early "3.09" guts into the later slip spline iron cases, several times. It's a good swap; not too hard, and good results.
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
 Post subject: Swap the whole thing
PostPosted: Fri May 30, 2003 8:45 pm
I intend on changing out the whole case. I'm putting in an 8 3/4 rear and have to shorten the driveshaft anyway. I figure the newer output flange is probably better anyway.
Mike
1965 Barracuda /6
 Post subject: Bearing retainer
PostPosted: Fri May 30, 2003 8:47 pm
I'm using a aluminum bellhousing so I already have the 5.125" hole.
1965 Barracuda /6
