| Steam cleaned cylinder... https://slantsix.org/forum/viewtopic.php?t=58819 |
| Author: | Valleyant [ Sun Dec 13, 2015 3:05 pm ] |
Maybe a crack between the valves into the cooling water jacket causing coolant to leak into that cylinder....... |
| Author: | wjajr [ Sun Dec 13, 2015 4:07 pm ] |
Cracked head most likely. Crack can be between valve seat and intake gasket, or somewhere on roof of combustion chamber in head. |
| Author: | that4wdwagon [ Sun Dec 13, 2015 5:58 pm ] |
Thats what I was afraid of.... |
| Author: | bcschief [ Wed Dec 16, 2015 4:27 am ] |
Also inspect the cylinder bore for signs of a crack it may look darkend and pitted around the crack |
| Author: | Dart270 [ Thu Dec 17, 2015 8:17 am ] |
It could also be a blown head gasket into the water jacket, but less likely. Fingers crossed... Lou |
| Author: | bcschief [ Mon Dec 21, 2015 2:52 pm ] |
What did they find ? Brian |
| Author: | slantzilla [ Mon Dec 21, 2015 3:37 pm ] |
If the plug was smashed, cylinder scarred, and piston top beat up something went through it. If you can feel dings in the cylinder with your fingernail the cylinder needs bored. I would guess that with 80-90 psi compression that motor is in need of boring anyway. |
