It is currently Tue Nov 17, 2026 7:26 pm
PostPosted: Thu Oct 22, 2015 7:22 pm
Car Model: 1965 BARRACUDA FORMULA Six
I'm gathering the bits to install a b&t 833 in my 66 Dart wagon and I'm curious if the shifter from a 1980 D100 will work. I know the shift rods are different lengths and the shift lever is different, but is the shifter itself compatible with a body b&t 833?
PostPosted: Fri Oct 23, 2015 7:59 am
Yes, the shifter itself will work fine.
PostPosted: Fri Oct 23, 2015 3:18 pm
is it correct that the only differences between a a833 shifter found in a D150 and a Hurst Competition Plus,, is the 1-2/ 3-4 stop bolts ?
PostPosted: Fri Oct 23, 2015 4:00 pm
There are some variations in the Comp Plus for different applications, but generally the Comp Plus only adds the stop bolts to a rigid-handle-mount shifter. The regular Hurst shifter with an isolated handle is what we got with the A833OD and most A833s.
PostPosted: Sun Oct 25, 2015 3:04 pm
Thanks for the confirmation. Got the shifter and the rods too just for kicks. Now I need a bellhousing.
The tranny is still in the truck and priced at $99+$30 core at the pick-n-pull Oakland if anyones interested.
PostPosted: Mon Oct 26, 2015 7:47 am
Why didn't you pull the bellhousing if you need one? Did you reply to my Craigslist ad for the bellhousing I'm selling? It's the same as in that pickup.
PostPosted: Sat Oct 31, 2015 7:49 pm
Sadly, the bellhousing was gone. I think I did reply to you CL ad. Vancouver? I or a friend can pick it up Nov 11th-13th. We're each driving opposite directions between Seattle-Oakland. Money talks, BS walks- I hope you still have it then.
PostPosted: Thu Dec 10, 2015 12:27 am
Thanks for the bellhousing, Josh. It cleaned up nicely. I'm making a ring for the input shaft bearing retainer, and shift rods coming in the mail. The whisky plank I'm lacking is the shifter-to-trans mounting plate. can anyone tell me if this one is correct for B&T 833 in a 66 Dart w/ buckets?
http://www.ebay.com/itm/64-65-HURST-SHI ... 6l&vxp=mtr
PostPosted: Thu Dec 10, 2015 8:20 am
The shifter mounting plate need to match the rods and stick you have.
Hurst made a lot of different plates and they all position the shifter at different angles.
What year / model vehicle are the shift rods from?
My notes show a 64 - 66 rods used a Hurst # 6348 plate for bucket seat A-Body vehicles.
The 67 - 76 used a 6350 plate... that one angles the stick forward and therefore, makes the rods a little longer.
(Look at where the lower threaded hole is on the plate, compared to the counter-sunk hole next to it)
I think there were other different different numbered plates, for bench vs bucket seat vehicles...
PM me if you need the 6350 plate I have.
PostPosted: Mon Dec 28, 2015 6:48 pm
Thanks, DD. I got the 2298 plate and an assortment of rods. Unfortunately, the only correct rod was 3/4. So, the hunt continues for correct rods.
PostPosted: Mon Dec 28, 2015 8:07 pm
Car Model: '23 T-bucket
Momentary Sidebar: "Geminimotors". Is this the same Gemini Motors that deals in gemini minibike parts? (supposedly has a stash of NOS parts?)
Roger
PostPosted: Tue Dec 29, 2015 7:08 pm
Haha, I wish! Also not to be confused with the Subaru dealer in Waterloo, Ontario.
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
