| torque converter rear end suggestions https://slantsix.org/forum/viewtopic.php?t=58884 |
| Author: | Montana A Body [ Tue Dec 29, 2015 11:12 am ] |
| Post subject: | torque converter rear end suggestions |
I plan on installing the following /6 into my 69 valiant: super six dutra exhaust(run duals all the way out?) 9.25-1 compression Erson 280/270 cam installed +4 1.72 intake 1.50 exhaust Hughes roller chain and Smith Bros push rods. 904 auto 8 3/4 rear end I was looking for a suggestions on torque converter and gearing thanks |
| Author: | ProCycle [ Tue Dec 29, 2015 11:22 am ] |
Race car, daily driver or a little of both? |
| Author: | Montana A Body [ Tue Dec 29, 2015 12:23 pm ] |
Weekend driver for the most part, there is a track less than ten miles from me, but more than anything just want to drive it to work some, and a trip around the area on the weekend, while trying to harass the occasional import. |
| Author: | slantzilla [ Tue Dec 29, 2015 2:47 pm ] |
I would use at least a 3000 stall 10" converter and a 3.91 gear. |
| Author: | Joshie225 [ Tue Dec 29, 2015 3:16 pm ] |
I would run duals back to the transmission cross-member area and then Y them together into a single pipe. I would also use a larger carburetor. |
| Author: | DusterIdiot [ Tue Dec 29, 2015 5:02 pm ] |
| Post subject: | LOL... x2...er...3... |
Quote: I would also use a larger carburetor.
...and more compression (that stick likes it up past 9.5 to 10:1 and higher on the rpm band).... and maybe index at +6.... and port the head so those valve sizes don't go to waste... duals per Josh's recommendation....390 cfm holley or 500 cfm for daily driving.... 500- 600 cfm for racing.... 3.23 daily driving would be OK.... my car really liked that setup with 3.55's even with the OD gear... EI and recurved distributor is a must small 4 barrel, more compression ratio, porting, large valves, per your post should ring in about 190hp at the crank...with Dennis's gearing and TC, 16's in the 1/4 for a not so sorted out car...closer to high 15's once you get everything dialed together or better.... If you did it right, the car will feel like a peppy 318.... |
| Author: | Dart270 [ Thu Dec 31, 2015 7:00 am ] |
I like your buildup specs quite a bit. Dennis has got the combo there - 3000 stall and 3.55 or 3.91 gears. The Holley 500 2bbl is a great street/track carb for your kind of combo. Some head porting, at least in the bowls, would be advised as well, as DI said. Best, Lou |
| Author: | Montana A Body [ Thu Dec 31, 2015 6:37 pm ] |
Thanks for all your suggestions. I appreciate them and will use them. Austin |
| Author: | killnine [ Thu Feb 04, 2016 10:01 am ] |
With all due respect to those posting suggestions, you can't possibly determine a good gear ratio without knowing how large your tires are. |
