| crank prep? https://slantsix.org/forum/viewtopic.php?t=58886 |
| Author: | Badvert65 [ Wed Dec 30, 2015 11:26 am ] |
| Post subject: | crank prep? |
Isn't there an article about prepping the crank? I can't seem to find it and could use some direction. |
| Author: | Greg Ondayko [ Wed Dec 30, 2015 1:18 pm ] |
Find the Lightest one you can with no cracks - Have it Magnafluxed to be sure. Doc Might have some more tips and tricks - He has ground down some pretty wild cranks over the years! Drill the Main Oiling Holes with a long 5/16 Drill bit Have your local machine shop turn and polish, balance it as needed. I have a bit of a write up if you look down this page: http://www.slantsix.org/forum/viewtopic ... &start=945 I spent a lot of time on that crank only to have too tight of a rod bearing ruin it. I have to get another one of those made some time (when I have time ) Greg |
