| valve setting https://slantsix.org/forum/viewtopic.php?t=58894 |
| Author: | mikewilliams [ Thu Dec 31, 2015 12:35 pm ] |
| Post subject: | valve setting |
Hey Guys...I need some help, I am putting a rebuilt motor back together and I need to know how to set up the valves so that she starts, from there I am good. could I get a step by step on this, or send me to a site.....Thanks Mike |
| Author: | ProCycle [ Thu Dec 31, 2015 12:39 pm ] |
First we'll need to know - solid or hydraulic lifters? |
| Author: | sandy in BC [ Thu Dec 31, 2015 1:30 pm ] |
After making sure your damper timing mark is indeed top dead centre and your cam is timed correctly you can set your valves cold. Use the same clearances as if the motor warm + .003" Start at TDC on #1 ...adjust valves...then hand roll the motor over and watch which intake valve is closing next....when that cylinder is at TDC adjust both valves. Go through all the cylinders twice to make sure. Many folks reset the valves once the motor is warm and running well. I set them again when everything is warm....but use the prestart method...and the correct lash. |
| Author: | mikewilliams [ Fri Jan 01, 2016 11:19 am ] |
That's not what I need....This is what I am looking for. #1cyl. at the top and TDC, set valves. rotate balancer to ?....And set #? valves rotate balancer to ?....And set #? valves I just put the head on and want to set the valves......Thanks Mike |
| Author: | sandy in BC [ Fri Jan 01, 2016 12:22 pm ] |
We dont know whats marked (or not) on your balancer. Quote: then hand roll the motor over and watch which intake valve is closing next....when that cylinder is at TDC adjust both valves.
.....153624 is your firing order.....cylinders fire 120 degrees apartset #1 at TDC....roll (the right direction) 120 degrees....set #5 (at TDC) Thats all fine.....but if I watch the intake valves ....and make sure THAT cylinder is at TDC..I am less likely to &#@% it up. |
| Author: | sandy in BC [ Fri Jan 01, 2016 12:24 pm ] |
There are other methods....but you will need to search for them |
