| Early Small Temp Sender Question https://slantsix.org/forum/viewtopic.php?t=59014 |
| Author: | neilskiw [ Sat Jan 23, 2016 11:16 am ] |
| Post subject: | Early Small Temp Sender Question |
Greetings, so my '64 Valiant temp gauge barely moves off the left edge. I grounded the sender wire with the key switch on and the gauge casually pegs to the right. I used a laser temp gauge on the thermostat housing and read 185 F. I'm thinking a new sender. Any other ideas? Does anyone know a part number for a replacement sender? Thanks! Neil |
| Author: | SlantSixDan [ Sat Jan 23, 2016 4:00 pm ] |
The early sender has larger thread (1/4"-27 dryseal) than the late sender (1/8"-27 dryseal), and your '64 does not use the early (up-to-'63) sender. It uses the later small-thread sender, Standard № TS-205. |
| Author: | neilskiw [ Sun Jan 24, 2016 9:20 am ] |
| Post subject: | Thanks Dan |
Thanks for clearing that up for me. My other convertible was a '63. Obviously I'm mis remembering the good old days. Thanks for the part #. Neil |
