| question for Dart owners. https://slantsix.org/forum/viewtopic.php?t=5905 |
| Author: | Guest [ Sun Jun 01, 2003 9:42 pm ] |
| Post subject: | question for Dart owners. |
In the rails that keep rain off your door(basically gutters above your doors) I was wondering what sealer stuff is used in their. Is it basically caulking, or is it something less sticky and resistant to cracking? If it isn't caulking then I was wondering if anyone could point me to where I would get this stuff. |
| Author: | '74 Sport [ Sun Jun 01, 2003 10:06 pm ] |
At your local automotive paint supplier, ask for a tube of joint filler. It goes on like caulk, but stays flexible. Jerry |
| Author: | DusterIdiot [ Sun Jun 01, 2003 10:11 pm ] |
| Post subject: | OEM use was body fillerin the drip rails.... |
If doing a resto the OEM use was body filler, many shops use that. joint filler is better, but especially in an area with some temperature extremes. Make sure you get a type that can be primed and painted, there are a couple of brands that are great for the hidden areas, but won't retain any coatings.... -D.Idiot |
| Author: | Guest [ Mon Jun 02, 2003 12:38 pm ] |
Thanks, that defineately helps! |
