| Interesting data on valve cover baffles https://slantsix.org/forum/viewtopic.php?t=59061 |
Page 1 of 2 |
| Author: | SlantSixDan [ Tue Feb 02, 2016 5:19 pm ] |
| Post subject: | Interesting data on valve cover baffles |
This page makes interesting reading for anyone fixing to install baffles in e.g. the Offy aluminum valve cover. The site belongs to a company selling an adjustable/tunable PCV valve for $129 (yes, you read that price right). It's an interesting idea the vast majority of us probably would not benefit from. But the baffle article is worth a read. |
| Author: | Will [ Tue Feb 02, 2016 5:30 pm ] |
Yes, very interesting. Changes will be made. Will |
| Author: | sandy in BC [ Tue Feb 02, 2016 6:46 pm ] |
Nice lil article. Thats the kind of tech that really works. Oil consumption of that magnitude could cause detonation . I like the way they scientifically checked their theory. |
| Author: | Badvert65 [ Wed Feb 03, 2016 4:47 am ] |
This brings up another question, relative to slant sixes. Does it make a difference if the PCV valve is in the front or the back of the valve cover? |
| Author: | Dart270 [ Wed Feb 03, 2016 6:38 am ] |
Nice work. Thanks for posting. They should have also mentioned to check carefully for rocker arm or pushrod interference with the baffle. If it was mentioned, I missed it. Best, Lou |
| Author: | Greg Ondayko [ Wed Feb 03, 2016 6:51 am ] |
Quote: This brings up another question, relative to slant sixes. Does it make a difference if the PCV valve is in the front or the back of the valve cover?
I would think not.Where ever you put it put the breather on the opposite end. Greg |
| Author: | Greg Ondayko [ Wed Feb 03, 2016 9:09 am ] |
Thanks for posting Dan! I enjoyed the thoughts presented in this article. Greg |
| Author: | SlantSixDan [ Wed Feb 03, 2016 10:04 am ] |
No, as long as it's as widely separated as possible from the breather.
| Author: | Greg Ondayko [ Wed Feb 03, 2016 4:03 pm ] |
This Brings up an interesting thought for me.. Does not apply to slant s or inline engines, Does it matter on a V-8 if the PCV is on the Right or Left Valve cover? as long as the breather is on the opposite side? Does the Windage direction of the crank adversely affect this flow in any way? Greg |
| Author: | SlantSixDan [ Wed Feb 03, 2016 4:05 pm ] |
Quote: Does it matter on a V-8 if the PCV is on the Right or Left Valve cover?
No.
| Author: | Nicademas [ Wed Feb 03, 2016 5:30 pm ] |
All these questions brings two to my mind. First would a crank case evc. system be a good choice on a daily driver? What would it do? Second what about a open filter breather? I am looking at replacing my valve cover so I can hammer out the original one in shape. I may just keep the after market one on if it works better. |
| Author: | SlantSixDan [ Wed Feb 03, 2016 7:38 pm ] |
Quote: would a crank case evc. system be a good choice on a daily driver?
No. Very bad choice. Quote: What would it do?
Fail to keep the crankcase clean, and make your exhaust dirty.Quote: Second what about a open filter breather?
Rotten idea.Quote: I am looking at replacing my valve cover so I can hammer out the original one in shape. I may just keep the after market one on if it works better.
They don't.
| Author: | Nicademas [ Wed Feb 03, 2016 9:16 pm ] |
Ok. So since my orginal breather had a fitting for a hose to the air box. And I am now using an open element air filter. Should I get a breather without a fitting and call it good? |
| Author: | Reed [ Wed Feb 03, 2016 9:23 pm ] |
You should get an open element air cleaner base that has a nipple for the breather or add a nipple. |
| Author: | Nicademas [ Wed Feb 03, 2016 10:02 pm ] |
Quote: You should get an open element air cleaner base that has a nipple for the breather or add a nipple.
Ok mine had the parts for it. I just need to drill a hole.
| Page 1 of 2 | All times are UTC-07:00 |
