| 4 bbl intakes? https://slantsix.org/forum/viewtopic.php?t=59093 |
| Author: | Badvert65 [ Mon Feb 08, 2016 5:31 pm ] |
| Post subject: | 4 bbl intakes? |
Is the Offenhauser 5270LK single 4bbl intake worthwhile? I don't really want to spend the cash on one of the Aussie intakes (and shipping). This would be primarily for drag racing. |
| Author: | Reed [ Mon Feb 08, 2016 5:36 pm ] |
If you are doing it just for drag racing, go with a Clifford. The Clifford have a larger runner crosssection and flow a bit better than the Offy. |
| Author: | DusterIdiot [ Mon Feb 08, 2016 6:05 pm ] |
| Post subject: | Yep... |
Quote: The Clifford have a larger runner cross section and flow a bit better than the Offy.
Agreed. You will be looking at Clifford shorty manifold, and headers. Offy is fine for the street, or mild street strip vehicle. |
| Author: | slantzilla [ Mon Feb 08, 2016 6:39 pm ] |
How fast are you wanting to go? |
| Author: | Badvert65 [ Mon Feb 08, 2016 7:03 pm ] |
I'm a Mopar guy...too fast is not enough. |
| Author: | slantzilla [ Tue Feb 09, 2016 12:06 am ] |
If you are trying to build a 14 second car you can live with an Offy quite well. Any faster than that get a Clifford. |
| Author: | DusterIdiot [ Tue Feb 09, 2016 6:28 am ] |
| Post subject: | Lol... |
Quote: f you are trying to build a 14 second car you can live with an Offy quite well. Any faster than that get a Clifford.
Remember, he's racing a '65 Belvedere...so he's a bit bigger and heavier than even a late A-body...to push it into the 14's without an adder, he needs all the help he can get... he should be pursuing the clifford intake,headers and a Jeffries head, if he's serious about being race only. |
| Author: | Badvert65 [ Tue Feb 09, 2016 7:09 am ] |
Race weight will be just over 3200 lbs (with driver). I have a set of Clifford headers and a ported big valve head. Compression ration comes in at 10.6 with thick head gasket, right at 11:1 with a thin steel one. I have two different cams, biggest one yields .474-I/.494-E at the valve. Still debating the converter, but am leaning towards a 2500-2700 stall for a race built, manual valve body 904 (75 vintage). I have 3.55 gears in it but have a set of 3.91 on standby (both sure-grips). Currently setting up a twin 2bbl intake but feel a single 4bbl may give better results. I am aiming for the D/G record so I'll need to best 14.1@97mph to set that. (Unless that has changed) I can't sneak anything past you guys.... 14 weeks to the Mason-Dixon race, oof! |
| Author: | slantzilla [ Tue Feb 09, 2016 8:59 am ] |
At 3200# you'll need more cam and converter, and 3.91 gears at least. 14.99 is easy, 14.1 is expensive. |
| Author: | Badvert65 [ Tue Feb 09, 2016 9:26 am ] |
I don't think anything is easy with only 225 cubes. I managed to get my 4200 lb (+ driver) 65 Fury to run low 12's in the quarter but that was with twice as many cubic inches. It's good to have a goal in mind. If it was easy, everyone would be doing it. |
| Author: | slantzilla [ Tue Feb 09, 2016 10:08 am ] |
I have done it. It's not hard, just expensive, and it's not a good retirement plan. |
| Author: | Dart270 [ Tue Feb 09, 2016 10:29 am ] |
Easy is for bums. The challenge is the fun way. Clifford 4 bbl is your best bet. Lou |
| Author: | slantzilla [ Tue Feb 09, 2016 11:02 am ] |
Quote: Easy is for bums.
And old men. Lou |
| Author: | Badvert65 [ Tue Feb 09, 2016 12:07 pm ] |
Quote: I have done it. It's not hard, just expensive, and it's not a good retirement plan.
Do me a favor and do NOT talk to my wife.
| Author: | slantzilla [ Tue Feb 09, 2016 4:46 pm ] |
