| Got a Slant https://slantsix.org/forum/viewtopic.php?t=5914 |
| Author: | GunPilot [ Tue Jun 03, 2003 10:34 am ] |
| Post subject: | Got a Slant |
Through a buddy on RamChargercentral.com, via a person on Pirate4x4.com, I recieved a complete, carb-to-pan-to-bellhousing Salnt 6. It supposedly has 30,000 miles on it, was in a truck, and was pulled in favor of a V8. It looks pretty good on the outside I was trying to ID this engine. I think I have it narrowed to a 77-80 version using the handy SS.org slant ID guide (http://www.slantsix.org/articles/parts-matrix/jpg.htm). Only question is: cast or forged crank. The block ID numbers go 030-12, 0457, with the suffix AAWJ. It has no spark plug tubes. I'd prefer a solid lifter, forged crank, but we'll see when we open it up. Any feedback on whether this is a worthy start on a race engine? |
| Author: | kesteb [ Tue Jun 03, 2003 12:51 pm ] |
Check the machined pad right below the #1 spark plug. If there is an E after the 225 then it has a cast crank. |
| Author: | GunPilot [ Fri Jun 06, 2003 12:33 am ] |
Upon closer examination, I have a 77-78 AAWJ block, solid lifters, cast crank. The head is casting # 3698447 which is the revised combustion chamber design with the small spark plugs. So, is this a suitable core for a race engine, or should I look for a forged crank? Should I put the head on an older, forged block, or should (can?) I install a forged crank/rods in this block? Or is the cast crank fine for HD use? |
| Author: | Doctor Dodge [ Fri Jun 06, 2003 11:31 pm ] |
Quote: So, is this a suitable core for a race engine, or should I look for a forged crank?
If you are going to build a Slant, I would find a forged crank engine.Should I put the head on an older, forged block, or should (can?) I install a forged crank/rods in this block? Or is the cast crank fine for HD use? In your case, where you have a nice low miles cast crank engine, use it. Mike Jeffrey ran the first 10 second 1/4 mile pass for a SL6 "doorslammer" with a cast crank engine. As for awapping-a forged crank into a cast crank engine, that does not work, the bearing sizes are different (smaller width) in a cast crank engine. DD |
