Shifter for A833 Overdrive
https://slantsix.org/forum/viewtopic.php?t=59175
Page 1 of 1
Author:  1957guy [ Mon Feb 22, 2016 7:09 pm ]
Post subject:  Shifter for A833 Overdrive
I have an 833 overdrive trans that came with a Hurst shifter and rods.The rods are obviously much too short so I assume they were deigned for a midship shifter mounting.My trans has the shifter mounting location at the rear of the output shaft housing.
Can anyone shed some light on the correct shifter and or rods that I should look for ?
Author:  DusterIdiot [ Mon Feb 22, 2016 7:33 pm ]
Post subject:  Which tailshaft and which rods?
Have you looked at the 4 speed article?
http://www.slantsix.org/articles/4-spee ... speed1.htm
It may shed light on the mystery, it sounds like may be you have one version of the transmission and a set of shift rods for the other...
