| Compressed Thickness of Head Gaskets https://slantsix.org/forum/viewtopic.php?t=59186 |
| Author: | 65 dartman [ Wed Feb 24, 2016 5:08 pm ] |
| Post subject: | Compressed Thickness of Head Gaskets |
It seems the Fel Pro compressed head gasket thickness varies on who you talk to (or read on the internet). Is there number that most slanters tend to use? How about a compressed stock steel head gasket. Inquiring minds would like to know. |
| Author: | DusterIdiot [ Wed Feb 24, 2016 6:12 pm ] |
| Post subject: | It's... |
Stock shim gasket is around .020- .022 Felpro weighs in from .038 to .043 (if just doing the calc split the difference). Victor Reinz is similar to Fel-Pro but weighs in on the "heavy side" (but they will take static compression ratios up through 12:1, where as I have had fel-pro fail out on 11:1 SCR engines- but were fine on 10:1 SCR builds) You will have to do a search if going to the realm of the Aussie Gasket or Copper Gaskets/ O-Rings. |
| Author: | 65 dartman [ Thu Feb 25, 2016 1:34 am ] |
| Post subject: | Re: It's... |
Quote: Stock shim gasket is around .020- .022
Are those numbers compressed or out of the box)
Felpro weighs in from .038 to .043 (if just doing the calc split the difference). . |
| Author: | DusterIdiot [ Thu Feb 25, 2016 6:13 am ] |
| Post subject: | Compressed |
Those are the compressed dimensions. |
| Author: | 65 dartman [ Thu Feb 25, 2016 6:14 am ] |
Ah OK! Many thanks for your input! |
| Author: | Dart270 [ Thu Feb 25, 2016 10:07 am ] |
I have measured maybe 10 Felpro gaskets over the years and they were always around 0.032 - 0.034" compressed (actually as installed in the engine - feeler gauges). The other brands are usually more - in the 0.038-0.46" range. The Aussie Permaseal/Endurotec are 0.044"-0.046" compressed. Lou |
