It is currently Fri Nov 20, 2026 3:52 pm
PostPosted: Mon Jun 02, 2003 10:45 pm
Currently, I have a Carter 1bbl carb that needs it's jets changed to accomodate a slant six 225. The jet's that are currently in the carb are to large and emitting too much fuel into the intake. Does anyone know what size of jet's and/or any other input I need to make this conversion ? Is their a part number or what ? Thanks very much for anyones help !
JJ Jones
PostPosted: Tue Jun 03, 2003 8:26 am
I could provide you with one, currently installed but am no longer using the carb. Don't know of a source for a Carter BBD jet. Need any other BBD parts leave me a pm with your needs. Have about 15 I use as part sources.
PostPosted: Tue Jun 03, 2003 4:38 pm
Weimar, it's unusual for a Carter BBS originally meant for use on a \6 to need rejetting. If your carb is running rich, it's probably due to a problem, rather than an incorrect jet. Broken step-up piston spring, stuck step-up piston, broken step-up rod, missing step-up cylinder gasket...
Most of these carbs come with a 2-263 main jet. One step lean is a 2-267.
PostPosted: Tue Jun 03, 2003 8:11 pm
:oops: :oops: :oops: :oops:
i thought you had a BBD :oops:
not sure about the Carter BBS, it was only used on the slantsix's, i dont even have any adjustment sequences for it at the moment :(
Justin
PostPosted: Tue Jun 03, 2003 8:31 pm
I'm not sure who said I am using a BBS type carburator; but in my orginal message I stated that I am using a BBD. Also, my engine was recently "completly" overhauled. Their is no question about too much wet fuel in the intake area. When removing the carb, I and the mechanic noticed that their was too much fuel. My father in law my have taken these carbs off a V-8; but I'm not sure about that.
PostPosted: Tue Jun 03, 2003 10:59 pm
Currently, I have a Carter 1bbl carb...
I just recently rebuilt my first Carter BBD..... it is a 2bbl.
Is yours 1bbl or 2bbl? I think we are all confused. :?
Jerry
PostPosted: Tue Jun 03, 2003 11:50 pm
BBS or BBD....my guess is that the carb has a leaking needle valve which is allowing excess fuel into the intake.
It could also be a loose floorjet or other loose parts. Loose parts will allow excess fuel to flow through.
