| 1967 Barracuda Dash circuit board question https://slantsix.org/forum/viewtopic.php?t=59192 |
| Author: | Kidd [ Fri Feb 26, 2016 7:58 pm ] |
| Post subject: | 1967 Barracuda Dash circuit board question |
So I pulled my Dash out in December to put a new speedo in, and new bulbs. Then I got sick.......so this week after work I have been getting it all back together. I realized that on the RH side looking at it from the back, there is not a plug under my dash for the 3 stud/pins on the small circuit board. My L blinker indicator that I thought was bad......dosent work, I popped the dash forward and REALISED that crap, I cant find where the plug is???? Then realized I didn't pull one off. So ???? I need to know if anyone has a 67-69 Barracuda, and what the plug or plugs look like that go on that side. What color are the wires? Any help would be great. Andrew/Kidd |
| Author: | neilskiw [ Sat Feb 27, 2016 8:28 am ] |
| Post subject: | Voltage Reducer |
![]() This little 3 pronged puppy lowers from 12 to 5 volts for your fuel and temp gauges. |
| Author: | neilskiw [ Sat Feb 27, 2016 8:36 am ] |
| Post subject: | Wiring Diagrams |
http://www.mymopar.com/downloads/1967/67BarracudaA.jpg http://www.mymopar.com/downloads/1967/67BarracudaB.jpg Of course the actual dash cluster isn't shown, but all the pins from the harness connections are. Also, I may have misspoke about the voltage reducer. Can't remember which year they began using those... :shrug: |
| Author: | wjajr [ Sat Feb 27, 2016 2:06 pm ] |
My Dart has broken pins on end of its circuit board. All I did was clean and solder jumper wires about 10 inches long on each of the small thin copper strips, crimped on Packard #56 (I think is the number) housed in a multi connector. Then removed the old round pin female brass connectors and their plastic housing from their respective conductors, and crimped on the mates to the new jumper harness/pigtail. (See new green, orange & yellow conductors) ![]() You can find the parts and connectors here. if needed. |
| Author: | wjajr [ Sat Feb 27, 2016 2:16 pm ] |
Quote: Also, I may have misspoke about the voltage reducer. Can't remember which year they began using those...
"They" have always used a voltage limiter, just some were housed within the fuel gage. I'm fairly sure limiter equipped fuel gage has three bolts holding gage to circuit board, where a non limiter equipped gage has two bolts, and that little three bladed turtle you nicely illustrated plugged into circuit board in plain sight along with a condenser to reduce "make and brake" noise from its contacts interfering with one's radio listening enjoyment. My homemade pig tail fix has been trouble free for nine years. |
