It is currently Thu Jun 18, 2026 10:52 pm
 Post subject: 198 or 225
PostPosted: Tue Mar 01, 2016 7:48 am
Car Model: 72 valiant
Hello,
Are there external cues that distinguish a 198 from a 225 cu.in. Slant six?
Or just bore /stroke?
1972 valiant.
PostPosted: Tue Mar 01, 2016 8:12 am
There is the engine ID number stamped on the pad on the lip on the block immediately behind the alternator and under the coil mounting bracket.
PostPosted: Tue Mar 01, 2016 8:40 am
If it has not been milled off during a rebuild.
PostPosted: Tue Mar 01, 2016 9:01 am
Keep in mind also that the 198 and the 225 use the same block (the difference is crank & rods) so there's a chance the stampings won't match the actuality. If you're sure the engine you're looking at has never been "remanufactured", then the stamping will tell you what kind of engine you're looking at.
PostPosted: Tue Mar 01, 2016 9:44 am
Thank you for replies.
Always on the search for slant six spares.
Users browsing this forum: Ahrefs [Bot] and 4 guests
