| Radiator 1973 Duster https://slantsix.org/forum/viewtopic.php?t=59230 |
| Author: | briang1964 [ Thu Mar 03, 2016 8:27 am ] |
| Post subject: | Radiator 1973 Duster |
So I needed a Radiator and after some searching it seemed the 1974 and up was available from Advance Auto 433497 . They did show one for the 1973 for a little more money but it was stated on another topic that the only difference was a larger trans cooler and a little taller. Well here is the difference and it does bolt into stock location except: It sits back further about 1-2 inches due to the mounting bracket. This moves the fan out of the shroud. Im guessing the 74 has either a deeper shroud or a longer fan. The bottom 2 fan shroud bolts are ok but top does not match up requiring drilling two small holes and using smaller bolts. I would like the fan to sit back into the shroud so may have to add a spacer. If you can only find a 74 Radiator it will work but not perfect. The core itself is bigger but overall size is the same due to smaller tanks. |
| Author: | DusterIdiot [ Thu Mar 03, 2016 5:07 pm ] |
| Post subject: | It's... |
Quote: It sits back further about 1-2 inches due to the mounting bracket. This moves the fan out of the shroud. Im guessing the 74 has either a deeper shroud or a longer fan.
You probably are running a fixed fan with the shroud?What was your original radiator part number? 497 is for 1975+ A/F bodies, the one in my 1976 Duster is a perfect fit, for the 1975 Valiant Shroud I have and the 1976+ 5 blade clutch fan....which sits a little closer to the radiator than the fixed fans and the standard fixed fan spacer... |
| Author: | briang1964 [ Thu Mar 03, 2016 6:19 pm ] |
YES its just a fixed fan. There are a few options I guess to run spacer, add a clutch fan or install an electric one. Ill see if there are any problems with it as is. |
