It is currently Mon Jun 22, 2026 12:18 am
 Post subject: pushrods?
PostPosted: Fri Mar 04, 2016 8:04 am
Ok, I have a head that was shaved .060 and when I put this on my 65 engine, I had problems in the pushrod - rocker arm adjuster area. With the adjuster screw backed out, a couple of the pushrods tended to pop out as there was apparently interference there. I corrected the problem by shimming the rocker shaft up with copper washers. I would prefer not spacing the rocker shaft so I was wondering if anyone has used shortened pushrods. Did they make their own or buy them? Is there a better alternative? I wonder because the deck has now been shaved and this will probably require more shimming. I am especially concerned as I will be swapping the stock cam out for something with more lift. I don't want the engine coming apart at the track if I can help that.
PostPosted: Fri Mar 04, 2016 8:40 am
Wait until you swap cams because your new cam may have a reduced base circle which could make your present pushrods ok again. If not you can measure and order pushrods from Smith Brothers or Manton.
PostPosted: Fri Mar 04, 2016 1:20 pm
Car Model: '64 Valiant Convertible
Greetings,
just wondering (out of ignorance) if the lifters could be machined shorter to achieve the same length?
Thanks. Neil
PostPosted: Fri Mar 04, 2016 1:28 pm
Car Model: 64 Valiant
Greetings,
Thanks. Neil
Not likely, the bottoms of the lifters have a radius ground on them, so unless you have an expensive precision grinder that can produce the radius on them, the shorter pushrods are the better solution.
