| How to determine a 60-62 head from 63+ https://slantsix.org/forum/viewtopic.php?t=59233 |
| Author: | kielbasa [ Thu Mar 03, 2016 1:53 pm ] |
| Post subject: | How to determine a 60-62 head from 63+ |
How do you tell if you have the early head that needs the spark plug washer vs the 63+ head that doesn't use the crush washer. Thanks |
| Author: | SlantSixDan [ Thu Mar 03, 2016 4:17 pm ] |
See if you can find a casting date on the head -- probably under the valve cover. |
| Author: | SlantSixDan [ Fri Mar 04, 2016 12:35 am ] |
Well, keen, a '72-'73 head is nicer than a '62 or '63 head. AFAIK, there's no external (outside the valve cover) clue to discern a '62 from a '63 head. |
| Author: | kielbasa [ Sat Mar 05, 2016 3:08 pm ] |
What makes the 72 head better than the 60 head? Does it have better chamber shape or something? |
| Author: | SlantSixDan [ Sat Mar 05, 2016 4:26 pm ] |
Yep, better combustion chamber shape starting in '67 for more complete combustion. |
