| pushrods? https://slantsix.org/forum/viewtopic.php?t=59237 |
| Author: | Badvert65 [ Fri Mar 04, 2016 8:04 am ] |
| Post subject: | pushrods? |
Ok, I have a head that was shaved .060 and when I put this on my 65 engine, I had problems in the pushrod - rocker arm adjuster area. With the adjuster screw backed out, a couple of the pushrods tended to pop out as there was apparently interference there. I corrected the problem by shimming the rocker shaft up with copper washers. I would prefer not spacing the rocker shaft so I was wondering if anyone has used shortened pushrods. Did they make their own or buy them? Is there a better alternative? I wonder because the deck has now been shaved and this will probably require more shimming. I am especially concerned as I will be swapping the stock cam out for something with more lift. I don't want the engine coming apart at the track if I can help that. |
| Author: | slantzilla [ Fri Mar 04, 2016 8:40 am ] |
Wait until you swap cams because your new cam may have a reduced base circle which could make your present pushrods ok again. If not you can measure and order pushrods from Smith Brothers or Manton. |
| Author: | neilskiw [ Fri Mar 04, 2016 1:20 pm ] |
Greetings, just wondering (out of ignorance) if the lifters could be machined shorter to achieve the same length? Thanks. Neil |
| Author: | CNC-Dude [ Fri Mar 04, 2016 1:28 pm ] |
Quote: Greetings,
Not likely, the bottoms of the lifters have a radius ground on them, so unless you have an expensive precision grinder that can produce the radius on them, the shorter pushrods are the better solution.
