| hub cap remover https://slantsix.org/forum/viewtopic.php?t=59255 |
| Author: | Tim Keith [ Sun Mar 06, 2016 9:24 pm ] |
| Post subject: | hub cap remover |
What works well to remove the 10-1/2 inch hub caps from the trucks and vans? I had no success with a paint can opener. I know of the special tools but which one works well for the least cost? |
| Author: | emsvitil [ Sun Mar 06, 2016 9:30 pm ] |
Doesn't the screwdriver end of the lug wrench work? |
| Author: | Tim Keith [ Sun Mar 06, 2016 9:39 pm ] |
The OEM lug wrench was missing. Would #5216018 work ? These 10-1/2 inch caps don't leave enough room for a screw driver to work. |
| Author: | Reed [ Sun Mar 06, 2016 11:01 pm ] |
If I can't find a tire iron, a flathead screwdriver has always worked for me. |
| Author: | coconuteater64 [ Mon Mar 07, 2016 6:50 am ] |
The only dedicated hubcap remover I have ever seen was for a VW Beetle. I would think a thin screwdriver would do the trick. Or maybe bonk it with a rawhide mallet? :shrug: |
| Author: | ESP47 [ Mon Mar 07, 2016 12:44 pm ] |
I have an old flat head screwdriver bent 90* at the tip that I keep in the trunk at all times. I also have a small piece of rubber I use under the pivot of the screwdriver to keep the wheels from getting dinged up. |
| Author: | Tim Keith [ Sat Mar 12, 2016 6:35 pm ] |
I got the OEM tire tool for the truck. |
| Author: | JNL [ Fri Mar 25, 2016 4:53 am ] |
Came across a picture of this tool in Stockel - Auto Mechanic's Fundamentals. Here's one: ![]() It's a glorified screwdriver! |
