spark plug gap
https://slantsix.org/forum/viewtopic.php?t=5932
Author:  zorg [ Wed Jun 04, 2003 11:16 pm ]
Post subject:  spark plug gap
Ok, I know this has been talked about before, but my searching didn't come up with anything, so here it goes again. What is the best gap for a stock 225 slant. My manual says .035, but it seems like I've heard that some of you run .040, is that right? Is there a performance difference, or should I just get the stock ones (in Autolites, of course)? Thanks
Author:  Dart270 [ Thu Jun 05, 2003 4:52 am ]
You can set the gaps to quite a wide range and it won't make much difference. 0.035"-0.040" will work just fine, so just use the stock spec.
