California model ONLY coolant temperature sensor
https://slantsix.org/forum/viewtopic.php?t=59331
Page 1 of 1
Author:  zzzfrog [ Mon Mar 21, 2016 2:56 pm ]
Post subject:  California model ONLY coolant temperature sensor
I am rebuilding the engine wire harness for a 83 dodge. Mice chewed the wires up. Using a 83 service manual to track the wires to their correct connection (by color coded wires) My question is regarding the California ONLY coolant temperature sensor. Can not find anywhere what sensor to buy. It is a two wire sensor with the prongs each on an opposite slant ( like this / \ ) (not the senders as I know what I need there) This sensor is used only on the California models. Does anybody have an idea where to get the proper sensor? None of the major auto parts dealers seem to have it.
Author:  Reed [ Mon Mar 21, 2016 3:57 pm ]
Can you post a picture? Is this mounted in the head or in the radiator?
Author:  zzzfrog [ Mon Mar 21, 2016 5:43 pm ]
It is at the front of the engine in the head near the thermostat housing. It is located near the sending units. Top of the sensor has been broken off and I have the connection which matches the configuration as shown in the service manual. The service manual states that this is only used in the Calif models. Will post a pic as soon as i can figure out how to upload it. Thanks
Author:  SlantSixDan [ Mon Mar 21, 2016 11:39 pm ]
4091 471. No longer manufactured. Pick a switch, any switch. Is this your switch?
Author:  SlantSixDan [ Wed Mar 23, 2016 11:03 am ]
(…you're welcome, glad to help out, don't mention it.)
Author:  Reed [ Wed Mar 23, 2016 12:10 pm ]
I appreciate your input Dan! 8) Thanks!
Author:  SlantSixDan [ Wed Mar 23, 2016 3:01 pm ]
Thanks, Reed, tho I was actually talking to zzzfrog.
(You Know You've Become a Grumpy Old Man When…
…you call people out on the internet for not using good manners! :lol: )
