It is currently Mon Nov 16, 2026 6:55 am
 Post subject: clutch help
PostPosted: Thu Mar 24, 2016 5:50 pm
hi have a 1976 d100 with 3 speed trans. started having prob shifting gears so adjusted the clutch and problem solved.I have had to do this more than a few times and clutch makes a ?roaring? kind of sound sometimes when I push clutch to the floor? Am running out of threads on the adjusting rod?!?!
PostPosted: Thu Mar 24, 2016 7:54 pm
Thats the sound of a throw out bearing as it nears the end of its life.
PostPosted: Thu Mar 24, 2016 8:46 pm
Yep I had that sound before mine went. DONT BUY ONE FROM O-REILLYS! They are made of pot metal and dont last. See here http://www.slantsix.org/forum/viewtopic ... ght=clutch
~Nic
PostPosted: Fri Mar 25, 2016 9:14 pm
thanks for replies guys.Nic looked at link to post about your clutch probs and it is a mirror of mine.i started by replacing the z bar bushings and have the bracket bending when clutch is pushed down too. mine is a 76 but I had to look twice at your pic,same color too! have never replaced a throwout.are there any links on here to it or any advice? thanks again guys
Users browsing this forum: Amazon [Bot] and 3 guests
