| Wiper Switch Wiring Diagram 1970 Dodge D100 Truck https://slantsix.org/forum/viewtopic.php?t=59348 |
| Author: | scraigallen [ Thu Mar 24, 2016 1:27 pm ] |
| Post subject: | Wiper Switch Wiring Diagram 1970 Dodge D100 Truck |
Anyone out there know what each of the wires do that go from the wiper switch to the wiper motor on a 1970 D100 Truck? My switch is pretty messed up and the aftermarket ones are pretty reasonable. But you have to know what each of the wires do. I have the wiring diagram, but that doesn't tell you what the wires do. The wire colors are: Large Light Blue from harness = presumed to be the main power. Red = ? Dark Blue = ? Green = ? Brown = ? Thanks, Craig |
| Author: | neilskiw [ Thu Mar 24, 2016 3:57 pm ] |
| Post subject: | Wich Model Motor? |
http://www.mymopar.com/index.php?pid=77 Above is a link to a page with part numbers of the various wiper motors. 2 speed, 3 speed, and variable. The wiring of the switch will likely be dependent upon the particular motor in your vehicle. Also, if your wiper switch is out, look for a part number on it. That number may cross to a newer switch for the motor you have. |
