| Valves https://slantsix.org/forum/viewtopic.php?t=59362 |
| Author: | zimmerman@bright.net [ Mon Mar 28, 2016 6:19 am ] |
| Post subject: | Valves |
Anyone know where I can get a set of P4286783 (I) and P4286784 (E) high flow valves for my /project? Thanks |
| Author: | DadTruck [ Mon Mar 28, 2016 9:42 am ] |
http://www.moparpartsgiant.com/parts/mo ... 86784.html http://www.moparpartsgiant.com/parts/mo ... 86783.html http://www.chicagoconnection.us/index.p ... cts_id=334 http://www.diyporting.com/angles.html |
| Author: | zimmerman@bright.net [ Mon Mar 28, 2016 10:15 am ] |
Thanks man they have exactly what I needed!!!! |
| Author: | zimmerman@bright.net [ Mon Mar 28, 2016 1:20 pm ] |
Oops, They say discontinued now. Any other guesses??? |
| Author: | slantzilla [ Mon Mar 28, 2016 4:56 pm ] |
AFAIK, most of the MP stuff for Slants is long gone unless it also happens to fit a small block or big block. Engnbldr valves still pop up once in awhile, but I think he was retiring too. Ferrea used to have a drop in that would work in Slants, but I do not have the part numbers. |
| Author: | Pierre [ Mon Mar 28, 2016 5:03 pm ] |
http://sivalves.com/2016-SI-Catalog.pdf Page 22. |
| Author: | Rick Covalt [ Mon Mar 28, 2016 5:15 pm ] |
The engnbldr exhaust valves are still on E-Bay, but he is definitely retiring |
| Author: | DadTruck [ Mon Mar 28, 2016 5:29 pm ] |
Quote: say discontinued
I kind of figured that, but what you were asking about was,,,standard valves with a back cut,, that is why I posted a how to link for cutting a valve back cut with a drill press, or any shop that does port flowing could also put in a back cut for you. so unless the standard valves in the head you have now are badly burnt, have them reground and a back cut added. You will have exactly what you were asking for. the Engine Builder and Ferrea valves listed are OS valves, |
| Author: | zimmerman@bright.net [ Mon Mar 28, 2016 7:02 pm ] |
Awsome, my shop says they can do the backcut on the valves. Thanks for the grind post. I'll get it to them. |
