| Timing possibly? https://slantsix.org/forum/viewtopic.php?t=59417 |
| Author: | 63dartconv [ Mon Apr 04, 2016 5:44 pm ] |
| Post subject: | Timing possibly? |
I just rebuilt my engine. I got my number one cylinder to tdc. Lined my cam and crank dots up. I have gas and fire. It's back firing through the carb. I rotated the plug wire each way and got back fire through the exhaust. Any ideas? |
| Author: | Joshie225 [ Mon Apr 04, 2016 5:57 pm ] |
When the timing marks on the sprockets line up the engine is on TDC for #6. Turn the engine 360°, line up the timing mark on the damper, then install the distributor for firing #1. Or just point the rotor to #6. |
| Author: | Doctor Dodge [ Mon Apr 04, 2016 7:47 pm ] |
Also, double check the firing order & valve lash settings. 1-5-3-6-2-4 For a first start on a fresh engine, the valve lash is better a little loose then a little tight. DD |
| Author: | 63dartconv [ Mon Apr 04, 2016 8:48 pm ] |
Sorry I'm not understanding you lol... Do I need to bring number 1 up or number 6? |
| Author: | Reed [ Mon Apr 04, 2016 9:10 pm ] |
Quote: Sorry I'm not understanding you lol... Do I need to bring number 1 up or number 6?
Both. Cylinders 1 and 6 move as a pair, but 180 degrees out of phase in the four stroke cycle.
| Author: | 63dartconv [ Mon Apr 04, 2016 9:12 pm ] |
Without taking the timing cover off agin, can I just move the plug wires 180 degrees? |
| Author: | emsvitil [ Mon Apr 04, 2016 11:40 pm ] |
No need to remove timing cover. Remove distributor, rotate 180 degrees, reinstall. |
| Author: | 63dartconv [ Tue Apr 05, 2016 8:36 am ] |
Ok thank you I will try that in a little bit |
| Author: | 63dartconv [ Tue Apr 05, 2016 9:39 am ] |
I got a cough out of it as if it was going to crank but that's it. It's getting fire and fuel |
| Author: | 63dartconv [ Tue Apr 05, 2016 9:53 am ] |
Ok got it fired off |
| Author: | Rick Covalt [ Tue Apr 05, 2016 1:01 pm ] |
Hopefully it runs Ok for you but none of the last 6 or 8 engines I have put together had the dots in the right place. Degreeing the cam is the only way to know. Rick |
| Author: | Reed [ Tue Apr 05, 2016 1:10 pm ] |
Quote: Hopefully it runs Ok for you but none of the last 6 or 8 engines I have put together had the dots in the right place. Degreeing the cam is the only way to know.
Ditto. I have dealt with new timing sets with the alignment dots as far as 8 degrees off.
Rick |
| Author: | 63dartconv [ Tue Apr 05, 2016 2:29 pm ] |
It ran but it didn't seem right..it's sitting on the ground running. I think I will take the cover off and degree the cam. When I originally built the engine, which was two years ago, I don't remember what my cam specs were. How will I go about that? |
| Author: | terrylittlejohn [ Mon Apr 11, 2016 4:39 am ] |
that is good, I thought something was wrong with me!! I never install a cam by dot location. it always seem to be a crap shoot. |
