It is currently Thu Jan 01, 2026 7:41 pm
 Post subject: Timing possibly?
PostPosted: Mon Apr 04, 2016 5:44 pm
I just rebuilt my engine. I got my number one cylinder to tdc. Lined my cam and crank dots up. I have gas and fire. It's back firing through the carb. I rotated the plug wire each way and got back fire through the exhaust. Any ideas?
PostPosted: Mon Apr 04, 2016 5:57 pm
When the timing marks on the sprockets line up the engine is on TDC for #6. Turn the engine 360°, line up the timing mark on the damper, then install the distributor for firing #1. Or just point the rotor to #6.
PostPosted: Mon Apr 04, 2016 7:47 pm
Also, double check the firing order & valve lash settings.
1-5-3-6-2-4
For a first start on a fresh engine, the valve lash is better a little loose then a little tight.
PostPosted: Mon Apr 04, 2016 8:48 pm
Sorry I'm not understanding you lol... Do I need to bring number 1 up or number 6?
PostPosted: Mon Apr 04, 2016 9:10 pm
Both. Cylinders 1 and 6 move as a pair, but 180 degrees out of phase in the four stroke cycle.
PostPosted: Mon Apr 04, 2016 9:12 pm
Without taking the timing cover off agin, can I just move the plug wires 180 degrees?
PostPosted: Mon Apr 04, 2016 11:40 pm
No need to remove timing cover.
Remove distributor, rotate 180 degrees, reinstall.
PostPosted: Tue Apr 05, 2016 8:36 am
Ok thank you I will try that in a little bit
PostPosted: Tue Apr 05, 2016 9:39 am
I got a cough out of it as if it was going to crank but that's it. It's getting fire and fuel
PostPosted: Tue Apr 05, 2016 9:53 am
Ok got it fired off
PostPosted: Tue Apr 05, 2016 1:01 pm
Hopefully it runs Ok for you but none of the last 6 or 8 engines I have put together had the dots in the right place. Degreeing the cam is the only way to know.
Rick
PostPosted: Tue Apr 05, 2016 1:10 pm
Rick
Ditto. I have dealt with new timing sets with the alignment dots as far as 8 degrees off.
PostPosted: Tue Apr 05, 2016 2:29 pm
It ran but it didn't seem right..it's sitting on the ground running. I think I will take the cover off and degree the cam. When I originally built the engine, which was two years ago, I don't remember what my cam specs were. How will I go about that?
PostPosted: Mon Apr 11, 2016 4:39 am
that is good, I thought something was wrong with me!! I never install a cam by dot location. it always seem to be a crap shoot.
Users browsing this forum: Google [Bot] and 7 guests
