| Rocker ratio? https://slantsix.org/forum/viewtopic.php?t=59463 |
| Author: | 63dartconv [ Thu Apr 14, 2016 6:27 am ] |
| Post subject: | Rocker ratio? |
I have a mechanical cam, lifters etc. I'm checking the cam degree. What is the rocker ratio on factory rockers? |
| Author: | Old6rodder [ Thu Apr 14, 2016 7:28 am ] |
1.5 > 1 |
| Author: | 63dartconv [ Thu Apr 14, 2016 7:46 am ] |
Thank you |
| Author: | ProCycle [ Thu Apr 14, 2016 7:46 am ] |
Last year I got myself all screwed up doing this. Where I live - in the motorcycle world - you measure valve timing at the valve. What I learned after wasting a bunch of time and confusing myself is that on a slant 6 you measure cam timing at the lifter. |
| Author: | Joshie225 [ Thu Apr 14, 2016 7:49 am ] |
Quote: Last year I got myself all screwed up doing this. Where I live - in the motorcycle world - you measure valve timing at the valve. What I learned after wasting a bunch of time and confusing myself is that on a slant 6 you measure cam timing at the lifter.
Yep. Do Not try to degree a cam off the rocker arm. Are you using the intake centerline method or just valve opening/closing? |
| Author: | 63dartconv [ Thu Apr 14, 2016 7:53 am ] |
Idk. Lol I've never done it with a wheel before. I have always used dot to dot so this is my first attempt at this. How should I do it? |
| Author: | Joshie225 [ Thu Apr 14, 2016 8:01 am ] |
http://www.compcams.com/technical/instr ... es/145.pdf Cam degreeing starts on page 8. Isky's instructions: http://www.iskycams.com/cam-degreeing.html Searching for "cam degreeing by intake centerline" gives lots of good results. |
