| Fuel cell sender question HELP https://slantsix.org/forum/viewtopic.php?t=5949 |
| Author: | Godspeedglen [ Sat Jun 07, 2003 6:59 pm ] |
| Post subject: | Fuel cell sender question HELP |
Alright guys, here's one for ya. Here's my situation.....I have noting but bad luck with gas tanks. I have a 65 Barracuda. That's the first problem....Try to find the proper filler neck grommet. I found one eventually but they always seem to leak. LOTS! I've checked the filler neck for roundness and cleaned it meticullasly. I've also checked the tank to see that it is straight. Yes, I have the right gasket. I bought the wrong one the first time. So here's where I'm at....I'm going to get an aluminum fuel cell. A twenty gallon deal that has all the proper hook ups for my fuel injetion. Now the catch |
| Author: | kesteb [ Sun Jun 08, 2003 7:41 am ] |
If can, buy one with a Ford sender. They have the same ohm range as chyrsler. |
| Author: | andyman225 [ Sun Jun 15, 2003 5:11 pm ] |
| Post subject: | grommet |
Where did you get your tank gromet from? Andy |
| Author: | RMDV [ Mon Jun 16, 2003 5:46 am ] |
| Post subject: | Re-Gas tank |
You can get the filler neck grommets from Laysons. I got two a few months back for a 63 Valiant. Need a gas cap for same. |
