safety trans shield
https://slantsix.org/forum/viewtopic.php?t=59504
Page 1 of 1
Author:  terrylittlejohn [ Wed Apr 20, 2016 2:54 pm ]
Post subject:  safety trans shield
I need advice on trans flex shields for ihra rules, I see the tci aluminum trans shield, I don`t know if this is the best? also I only see a sb flex shield steel can these be modified to fit a slantsix pattern and pass safety inspection? any help
Author:  slantzilla [ Wed Apr 20, 2016 3:51 pm ]
I can't remember who, but someone used to make one for the Slant.
Pretty sure modifying a V-8 one is a no-no. :D
Author:  terrylittlejohn [ Thu Apr 21, 2016 4:25 am ]
thanks , I don`t know how strict they are going to be , this is going to be the first full season for IHRA rules, if I read them right anything over 6.99et in the 1/8th you need both.
Author:  sandy in BC [ Thu Apr 21, 2016 9:17 am ]
Are they asking for SFI approved?
I was able to make my own Kevlar flex shield and get it passed by my sactioning body.
Author:  terrylittlejohn [ Thu Apr 21, 2016 10:53 am ]
no sandy they haven`t asked but they did make me replace my belts because of exspired dates , I`m hoping to increase the blower drive and this hopefully put me into the 6.99ets which if I am reading the rules for super pro brackets I need flex plate and trans shields. I was thinking if I had a sb flex shield and made flat bar exstention if it could pass.
Author:  Fopar [ Thu Apr 21, 2016 11:38 am ]
Check out Tom Waters in Florida, That is who made my SFI approved metal flexplate shield for the slant six. Metal ones you get 5 years before recertification.
Richard
Author:  terrylittlejohn [ Thu Apr 21, 2016 6:11 pm ]
is he on this site?
Author:  Fopar [ Thu Apr 21, 2016 10:48 pm ]
No http://racecarpartsdepot.com/ Should get you to his contact info.
Richard
Author:  Greg Ondayko [ Fri Apr 22, 2016 10:14 am ]
I have gotten SB SFI flexplates for the LA engine and modified them to fit the slant - They were sfi Approved when new - not sure now?
Here's a blurb on what I did:
http://www.slantsix.org/forum/viewtopic ... &start=195
Author:  terrylittlejohn [ Fri Apr 22, 2016 3:41 pm ]
I have the v8 sfi flex plate but the flex shield is my problem.
Author:  terrylittlejohn [ Fri Apr 22, 2016 3:42 pm ]
who carries a sfi damper for a slantsix, I know bb dodge can be used.
Author:  Greg Ondayko [ Sat Apr 23, 2016 5:36 pm ]
Here's what I used on ruster and the 69 dart if you need a sfi and stock type pulley location.
http://www.slantsix.org/forum/viewtopic.php?t=18147
Usually can be found on eBay
Author:  terrylittlejohn [ Sat Apr 23, 2016 7:02 pm ]
finial got answer back from track rep, I need the sfi damper, I have the romac coming. I need the trans shield at 6.99et and the flex shield at 6.50et. now I just need my first sub 7sec/et.
