It is currently Thu Jan 01, 2026 2:36 pm
PostPosted: Wed Apr 20, 2016 1:51 pm
Pulled the head off today... opinions on that redish color on cylinders 5 and 6? Is that just the junk left from the additives in the gas?
Tops of pistons:
5 and 6 on the head
70 Plymouth Valiant 4dr
 Post subject: Yes additives
PostPosted: Thu Apr 21, 2016 8:50 am
Have you by chance been using an octane boost product? Many of these contain organic/metal complexes that leave reddish residues upon combustion.
https://tinyurl.com/yynpj4v2
 Post subject: ...for example
PostPosted: Thu Apr 21, 2016 9:02 am
Methylcyclopentadienyl manganese tricarbonyl (MMT) - leaves magnesium oxide deposits
Ferrocene - leaves iron oxide deposits
Iron pentacarbonyl - leaves iron oxide deposits
They all are effective at raising octane level but are self defeating because they also eventually leave crust that promotes detonation, particularly the iron compounds.
Best octane boost available is either tetra ethyl lead or even better is iso-octane, otherwise known as 2,2,4-trimethyl pentane.
Brian
 Post subject: Correction
PostPosted: Thu Apr 21, 2016 9:04 am
Sorry, obviously MMT leaves manganese deposits not magnesium
PostPosted: Thu Apr 21, 2016 11:34 am
ahhh i see.... every 8,000 miles or so, i put water remover / octane booster in the gas tank.. many of the gas stations around where i live have water issues..
that explains the reddish color.. awesome.. thank you guys...
 Post subject: additives
PostPosted: Thu Apr 21, 2016 12:57 pm
Water remover is fine, but those octane boosters are leaving the residues.
b
 Post subject: iso-octane
PostPosted: Thu Apr 21, 2016 1:04 pm
Forgot to mention, iso-octane is actually the standard for octane rating, it is 100 octane. Of all the isomers of octane, 2,2,4-trimethylpentane burns the most efficiently, because it isn't a long carbon chain, it's more of a spherical-shaped molecule and is thus very volatile and burns very evenly.
When discussing fuels having octane ratings above 100, usually oxygenated additives are used to get the fuel to burn even better, faster, more evenly, e.g. alcohols, ethers, nitrous oxide, and the like.
If you are going to use high octane fuels, stay away from additives with metals in them, better to use only organics, like alcohols, ethers, iso-octane.
Brian
PostPosted: Fri Apr 22, 2016 6:26 pm
I've been finding the reddish-brownish deposits in engines for decades with no octane boost. Nothing unusual.... I just assumed it was in the fuel additives.
Now the orange color on that one valve is certainly different.
 Post subject: engine additives
PostPosted: Fri Apr 22, 2016 8:38 pm
No telling what the various oil companies put in their gasoline. Many advertise "cleaning agents" and "detergents" and "corrosion inhibitors," can't say what these are and the regulators don't really put any responsibility on them to divulge what's in them.
brian
