It is currently Sun Nov 22, 2026 12:58 pm
 Post subject: Pro Line Dual Webers
PostPosted: Mon Jun 16, 2003 9:45 am
PostPosted: Mon Jun 16, 2003 10:00 am
Not sure if anyones running that setup on this site, but i know atleast 2 or more people are on www.slantsix.com
From what i've heard these things are a perfect fit, are tuned for a near stock slant so you just gotta bolt em on and go pretty much, if you have an Auto you'll need a Lokar Kickdown linkage from summit racing (its $55). Also the owner (?) of prolinefuel posts over at .com
Justin
PostPosted: Mon Jun 16, 2003 5:17 pm
WWW. Prolinefuel.com, liked the sight so much, I down loaded it as they included installation/service tips. Impressed with the duel set up espically.
PostPosted: Wed Jun 18, 2003 4:24 pm
I have the proline setup on my 71 dodge truck and other than the carbs being a little finicky in wet humid weather they run real well(I think that the front carbs float is a little high as it seeps around the gasket but im kinda wary about ripping in to the carb as I know very little about webers).
Overall I like them.
Ive got a slanted attitude and a heavy right foot.
PostPosted: Thu Jun 19, 2003 12:55 pm
Proline currently has a set up on E-bay if that helps.
go fast, turn left, don't screw up.
WWW.Mopardropheadcoupe.com
PostPosted: Tue Jun 24, 2003 7:44 am
:) I have ordered the system from Chris. Hopefully their in the mail now. Looking forward to putting them and Dutra Duels in when they arrive. Guess a ignition upgrade is next. Thanks Cam
