Cam Choice
https://slantsix.org/forum/viewtopic.php?t=59539
Page 1 of 2
Author:  63dartconv [ Tue Apr 26, 2016 5:51 pm ]
Post subject:  Cam Choice
So after talking with a couple people on here about the cam I originally went with, they advised against it.
What is a good street cam with noticeable idle? I am running a 4 barrel Offy with 500 EB, Headers, .100 off of the head, stock TC and gears.
Author:  Joshie225 [ Tue Apr 26, 2016 6:44 pm ]
The stock torque converter and your desire for a "noticeable" idle are at odds with one another. If you get that noticeable idle you're likely to hate driving the car for the lack of low speed performance. I wouldn't change the cam without changing the converter unless it was a very short duration cam and then you don't get your desired idle.
Author:  63dartconv [ Tue Apr 26, 2016 6:46 pm ]
Ok thank you!
Author:  63dartconv [ Tue Apr 26, 2016 6:54 pm ]
What is a better than stock cam with good street manners then without changing TC?
Author:  DadTruck [ Wed Apr 27, 2016 5:19 am ]
see this thread
http://www.slantsix.org/forum/viewtopic ... light=rv10
and this thread has info on street hydraulic cams
http://www.slantsix.org/forum/viewtopic ... rpm+torque
Author:  Joshie225 [ Wed Apr 27, 2016 7:40 am ]
I second the RV10 recommendation. I also like the Oregon Cam Grinding #819 as an intake lobe and the #818 for the exhaust on 108° lobe separation. This would give a short seat timing of 248/240° with 219/212° at .050" and .437/.431" gross lift. This is a couple steps up from stock and would take advantage of the raised compression ratio without killing the bottom end torque and making the car a slug at stop lights. I know you had .100" taken off the head, but it is a very good idea to measure deck height and combustion chamber size in order to determine the true static compression ratio.
Author:  Rick Covalt [ Wed Apr 27, 2016 2:13 pm ]
The 819 lobe is what I have in my truck on both intake and exhaust. I like it very much. Will see what it runs in the 1/4 in about 3 weeks.
Rick
Author:  Joshie225 [ Wed Apr 27, 2016 2:27 pm ]
When I last road raced my 225 powered Dart it had the Oregon 819 cam with a home ported big valve (1.78/1.45") head and .100" milled off both the head and block. The compression ratio was probably near 10.5:1 and I ran it on 100 octane low lead av-gas. It would pull to 5800 RPM. I didn't have the oiling system up to snuff and ventilated the block when a rod bearing got hot and the rod failed.
Author:  Dart270 [ Thu Apr 28, 2016 3:06 am ]
With the stock converter and gears, and your engine setup, I like either the 819 on both I+E or the 819/818 as Josh says. Those cams will be about as big as you can go and still use the stock converter. I don't see the RV10 specs in those threads, but as I recall it is very close to stock, in my book. Degree the cam at 100-102 centerline.
Author:  slantzilla [ Thu Apr 28, 2016 12:20 pm ]
Spend the money for a converter first and build your motor later. A stock motor with a loose converter will run a whole lot better than a cammed up motor with a stock converter.
Build from the back to the front for happiness. :D
Author:  Dart270 [ Thu Apr 28, 2016 12:34 pm ]
That's the best advice I've heard all day...
Author:  Joshie225 [ Thu Apr 28, 2016 12:46 pm ]
Love it!
Author:  Rick Covalt [ Thu Apr 28, 2016 1:07 pm ]
That is why I always put a new tailpipe on all my vehicles 1st!! :lol: :lol:
And I am running a stock convertor on my truck with the 819 cam.
Rick
Author:  slantzilla [ Thu Apr 28, 2016 3:28 pm ]
Rick
Yeah, but you are special. :lol: :D
Author:  Killer6 [ Fri Apr 29, 2016 9:01 am ]
Ding! 8)
Page 1 of 2 All times are UTC-08:00
