HX35 Turbo Placement
https://slantsix.org/forum/viewtopic.php?t=59548
Author:  casedawg [ Thu Apr 28, 2016 8:21 pm ]
Post subject:  HX35 Turbo Placement
I now have an HX35, so where do you put it? I saw Pro Cycle cut down the stock manifold and welded a flange to it and put the turbo right next to the block. That seems like a decent place for it. Can I keep the stock oil dip stick with it there? Are there any other clearance issues with it located there?
For those that are using the HX35, what did you do for your downpipe? Did you cut off the stock elbow and weld on a v band flange?
Author:  casedawg [ Thu Apr 28, 2016 8:45 pm ]
I have the 7 blade HX35W. How does one reduce the boost down to the 8-15psi range? I am going to be running the MS3-Pro so I have boost control available but I'm not sure what's needed on the hardware side.
Author:  Junior [ Fri Apr 29, 2016 7:37 pm ]
<img src="http://i125.photobucket.com/albums/p79/weesers1/Mobile%20Uploads/20141221_113629_zpso1igjljt.jpg" border="0" alt=" photo 20141221_113629_zpso1igjljt.jpg"/>
watch out if you use an internal wastegate. mine barely clears the intake.
<img src="http://i125.photobucket.com/albums/p79/weesers1/IMG_20140814_134314_098_zps2c67548a.jpg" border="0" alt=" photo IMG_20140814_134314_098_zps2c67548a.jpg"/>
used 3" flex pipe.
no idea what you would need to control boost using ms3.
Author:  casedawg [ Sat Apr 30, 2016 12:04 am ]
What blow off valve are you using?
Author:  Junior [ Sat Apr 30, 2016 5:13 pm ]
that is a snyapse. i was running an ebay bov. that worked fine. made the fast and furious whistle noises. lol. the synapse is a much better unit though.
Author:  mopars biggest fan [ Thu May 19, 2016 10:14 am ]
I made my own manifold
Author:  Ccrussell [ Tue Jan 24, 2017 8:08 am ]
Hi
I too am going to run a Holset hx35. How did you resolve the wastegate issue? How are you limiting to under 15 psi?
Reading, collecting parts, waiting.
Russ
