It is currently Wed Dec 31, 2025 7:19 am
 Post subject: Cross fit headers?
PostPosted: Sat Apr 30, 2016 1:53 pm
I should know this, but. I recently bought an engine for my 66 Valiant. The motor came with a Clifford water heated intake, 390 Holley, and headers. The engine had been in a 69 Barracuda.
No the question. The 69 headers into a 66. Is that something I can make happen, or am I looking at get another set for this car?
66 Valiant, 225.
84 Van, 225.
71 Maxi-Van, 318
60 Valiant wagon, 225
87 Maxi-Van, 318 4spd
 Post subject: Afaik...
PostPosted: Sat Apr 30, 2016 4:29 pm
Clifford shorties are the desired headers for the pre-67 cars...if they are the clifford long tube headers (2 halves 3 into 1- collector would be down by the oil pan rail and crosslink...)you will need a later car, a bigger car, or you may be able to cut them up and see if you can "reconfigure' the set, but that's a lot of work....
PostPosted: Sun May 01, 2016 7:41 am
If Clifford Shorties, then no problem, as Josh said. Post a pic and we can tell you which headers they are.
